Thinking About Replacing Powerflex Dogbone Mount
I bought my vRS back in December and it needed new drop links and arb bushes replacing so I had these done straight away, at the same time I had a new yellow powerflex dogbone mount fitted that came with the car. Now I know that these do produce more vibration through the car and that they should settle down after a few thousand miles but mine really hasn't. Its actually spoiling my enjoyment of the car now. It even got to the point were my daughter was sick in the car due to vibration when stuck in traffic and at idle. So I'm after peoples opinons on where to go next? The options I see are as below:
Powerflex diesel purple bush
Superpro blue
standard oem
All opinions are welcome.
H
Might be worth checking its fitted right 1st
Also checkout the engine mounts - these might be worn
Superpro blue would be better bet for a road car than yellow.
The THS mounting kit could be worth consideration.
If you're sure its the dogbone, ands nothing wrong it, replace it with a THS dogbone and sell-on the yellow-ed one you've got fitted.
I'm going to be fitting my coilovers on Sat so will have a look at it the while I have the car in the air. In what way can it be fitted incorrectly? Does any one know the torque settings for the bolts etc?
bushes incorrectly pressed in, angle of the whole dogbone being incorrect and the like
Coilovers affect NVH enough anyway, I'd stick with OE bushes on a daily road car personally.
Ok so back standard it looks like then. Now I've just had al look on ebay and there are a few complete dogbone mounts for sale. Would it be a false economy to buy a cheapish one or should I stick to oem?
Stick to OEM false economy with rubber bushes
I'm running a THS dog bone - nice and smooth
I got a yellow PF rear one and it settled down after about 1k
Just had the Superpro front bit fitted, and it was harsh but after 350 miles i have noticed getting better already, by the 1k mark it should be happy.
Strange yours hasn't settled though, as said check the engine mounts, as this made now end of difference to the general noises of the car when I changed them a few weeks back, engine side had detached itself inside the mount
Cheers for the info, I've just had a look at the engine mounts with my fitter at work and there doesn't seem to be real excessive play or movement so I may just go back to standard dog bone and see how it goes from there for the minute as I've got lots still to do and the list seems to be growing lol.
I`ve got the Superpro version, works fine from day one - recommended
those of you who got vibrations and harshness after fitting PF dogbones....are you sure you have install them correctly?have you clean the mount and put the grease before putting the poly bush
Mine was fitted by my local garage so I don't know if it was fitted correctly. Going to have a look Saturday.
I've just ordered the THS mount :rock: gonna give that a try and I can all ways sell my PF mount to recoup some of the cost. :blush:
I have fitted the yellow powerflex dogbone mount, I get more vibration through the car at certain revs, It feels like the exhaust is hard on the floor of the car!
I am thinking of refitting an OEM one again!! was a much better I think
this has been talked over so many times on the forum, powerflex seem to be firmer/vibrate more than the superpro bushes, so if you want the upgrade without the harshness change from powerflex to superpro.
350 already?!? I only sent it a few days ago :)
I have the Powerflex dogbone bushes, well the two rear ones not the round middle one, and I didn't notice any extra vibes.
My car's pretty solid generally though with polybushes front and rear and my bouncy VMAXX coilovers.
the powerflex as a different durometer rating (i think thats the term) to the superpro.
i adjusted my idle through vag.com to stop the car vibrating at the wrong frequency on ticover, made quie a difference to the idle noise in the cabin by a minute adjustment of the engine idle.
Ah the plot thickens OET has reminded me that I too upped the idle at some point.
Thats why mine is happy
Jeez I'm over 400 now, 500 by monday lol, I'm a busy man
Superpro blue
standard oem
H
I have Powerflex ,the red one....0 vibrations from the first mile
I had the SuperPro blue in my old Octavia and initially it was a bit harsh but after 300 or so miles I didn't notice it. The main thing was that SWMBO didn't notice any change at all so it can't have been that bad.
its got to be tightened just right, but not overtightened otherwise it will vibrate, so its worth checking tightness!
By Sunday morning I was up 750 miles lol
A quick detour to heathrow Saturday helped mind you
