Rear Beam Bushes
Hi all i have to change my rear bushs can i use the nuts+bolts that are on it or get new ones
Stu
best practice is get new, but i have seen reused, the last ones i changed the owner didnt buy new bolts so we cleaned up the old and reused them.
for the price they are, get new, just incase it is any hassle re-using (you may strip a thread/break a bolt when removing)
Which bushes are you fitting? standard ones or uprated?
Ok will get new cheers guys ;-)
if you are fitting yourself you will need to make/get a press to press the new bushes back into the beam.
Just standard one got to change the rear coil springs too then see about
A new exhaust
have only ever fitted polybushes, but i would imagine you need a press none the less for stock bushes.
Yep VAG do a proper tool for it or you can make your own tool up with a long bolt and nuts and metal plates.
Best rear beam bushes to fit are the Fabia ones or Leon Cupra R ones as they're a much better design than the Octavia ones.
or superpro:>
super write up, thats exactly whats needed! the superpro bushes are 2 piece, the powerflex are one piece and def need a press tool
Silly question do i get the new nuts+bolts from the dealer
Stu
yes you do, they are vag specific, tho am sure if you could get the same in high tensile/locknut type affair it would be no issue
I replaced mine when I changed my rear beam bushes, but upon looking at at them, they were nothing special.
