Constant or ignition live in boot?...
I'm thinking of putting a ciggy lighter socket in the boot. Can anyone direct me to either a constant or ignition live wire somewhere in there? And if it was a constant would it drain the battery?
I also have a sub if this helps!?
Combi has a lighter socket in the boot as standard so so you could have a look @ the wiring diagram for one and see where it takes the feed from.
Or piggy back from the current ciggy lighter? straight under the carpet to the rear?
Exactly what I did!
I did think of that but I hoped there was a quicker and easier way just to piggy of some wires in the boot to save me trailing wires.
Rear seats are really easy to remove tho? so might not be as big a job as you think
Off the amp for the sub sounds the easiest to me m8
