Front fog lights
Hiya folks, this is probably in the wrong place, but i will give it a bash
Ive recently picked up my fabia vrs and noticed that the front drivers side fog light isnt in the setting correctly and is lose.. how much of an easy fix is this bearing in mind i havent done any sort of work on a car in years.....
Any help would be really appreciated.
Cheers folks :sweat:
Not sure if it's different on the vrs, but for my model you just pull the fog surround off (sharp tug), then check all screws are in place and that it's mounted correctly.
Cheers...
Access is limited without removing bumper or headlight I understand but as above check everything is tight and no mounts are cracked or broken off
ah right, i feared i might have to remove the bumper.. may leave leave it to wobble..lol, i will go and have another wee look and see if i cant pull the whole thing out.. cheers guys :whew:
well, after popping the small grill off infront of the fog light i discover that the clip that holds it on has snapped off totally, does this spell disaster or an easy fix..??
Yeah new fog light needed, they aint too expensive
nothing that a well placed cable tie wont sort out!!
