Cheapest branded clutch? (incl flywheel, bearing and odd's and end's)
Yeah euro car parts I think its £370 all in
Really don't have the patience to order every single last bit piece by piece. I don't even know what I need but thanks for the input anyway dude (y)
Its not hassle just give them your reg and tell them you need dmf, clutch and concentric bearing. :) thats all
Do I not need all this ****?
240mm Dual Mass Flywheel
Clutch Disc
Pressure Plate
Release Bearing
Flywheel and Pressure Plate Bolts
Installation Lube
Edited by ROS53Y
I just took mine to Mr Clutch and let them do it. 2 year warranty as well and miles cheaper than anyone else
clutch will come as a kit from euro including bolts, the lube will be supplied by the fitter, if that you then yeah you need the lube.
bad experience from Mr clutch.
Did he not use lube?
My dmf is fine and I launch at every set of lights I come accross. Had hybrid for 10k'ish... 273ft/lb and 201bhp. Always accelerate from as low rpm as I like. Always pull from 40-60 in 6th foot to floor. Pure abuse. Only time I can get the clutch to slip is if I do 3 or 4 2nd gear burnouts from reverse lol may slip then. Standard clutch and flywheel ftw. On around 50k miles now. Ps don't buy my SE.
Hmm....
I'd say you'd be better off with a SMF instead of DMF
