Would these wheels fit?
I currently have 165/70R14 on my car. Would 195/65R15 fit onto my car? Obviously not on my current wheel but the alloys I want have these size tyres.
Should do
On the basis the with 16's you have 205/45/16 and 17's 205/40/17. A 5mm drop in tyre profile that is.
no there would be approx. 8% difference in rolling diameter, which means your brakes will be working much harder and your speedo will be significantly under reading. anything over a 2% difference is not generally advisable
My current wheel are 14" and these are only 15" alloys?
I would think more likely a 195/55/15
Have a look in the owners manual it should state tire pressures for differnent tire sizes available for the fabia
And see what sized tires skoda deemed suitable for the fabia with 15" alloys
These are the wheels. Would they fit my 2007 fabia? Non vrs http://bit.ly/Ljx9Cu
Edited by IllusionEntity
yeah so the rims are an inch bigger, and the side walls are nearly half an inch taller. thats quite a big difference
as above 195/55/15 would be the nearest size
The wheels will fit as they are the same stud pattern etc, but you would have to change the tyres. if you left those tyres on when your speedo reads 70mph your actual speed would be 75mph.
I reckon the best tyre size would be best at 185/55/15 as this would mean your speedo would only be out but 1mph or so.
This website may help shed some light
http://www.alloywhee...Tyre_Calculator
Edited by kotlewski69
Should do
the profile measurement is a percentage not mm. . .so it'd be 65% of 195. . .and the old one 70% of 165. .
Edited by vrs'burks
