removing front grill
how do you remove the front grill? do ii need a tool to press the plastic pegs together?
OH NO............not clips again.
Or if you have a hex bit holder (the bit that holds the various screwdriver heads) from a screwdriver set that works too i used it to take mine off, found it easier to use than the socket
:giggle:
Do you have a cooker on the front of your car, I have a GRILLE :giggle:
cooker thanks handy for BBQ's. :rofl:
  • 2 months later...
No, there's a very easy way of doing it. Push a 6mm socket over the bits sticking through the bonnet. As you press the socket towards the bonnet, the clips are released by pressing the pegs together equally around their circumference, and will not break. 6mm is the ideal, 5mm too small to go over the pegs, 7mm too wide to compress the clips enough to release them
Dead simple to do, it doesn't even need any effort to press the socket on.
Mike
I am wanting to replace the grill of fabia 2 can you share a screen shot of how this can be done, i see 2 screws on the top and then some kind of rivetted screws and stuck on how to remove the grille.
