"Wobbly" Idle on VRS
Just got my Limited Edition VRS Diesel
When standing in traffic the idle can sometimes be a bit wobbly. Rev stay constand but it's almost like a lose engine mount ?
Anyone else have similar symptoms ?
Ta
Neil
Mine does this as well I do think I have a worn engine mount though. Can you feel it chugging slightly when sat in the seat?
Yes and if I blip and release the throttle it causes it too.
Only 36k miles so I think it's a bit young to have worn the mount ?
If it is a diesel it will be the flywheel :whew: ( Dual mass ) people replace for a single mass one
I have a years warranty so shouldn't be an issue but just in case, is it a big (ie expensive) job?
Neil
My PD170 does this too, same mileage, no warranty.
FYI i dont think the clutch and components are covered by Skoda warranty if thats what you have
I had a brand new (OEM) dual mass flywheel and clutch with new hydraulic cylinder and it still did it FYI.
Seems a feature to some cars. I solved mine by changing the idle speed slightly.
Does the diesel have a pcv valve like the tfsi? They are well known for causing lumpy idle.
