can anyone help?!
driving home quite spiritedly with my mate in his lcr and my eml came on, got home and vag com'd and this is my fault code...
Edited by rich53
my turbos only a few months old, theres no way my vnt has gone already :(
this is a log i did on vagcom not a clue if its correct im gussing it just did the max reading? 3rd gear 2-4k rpm...
19:19:31
5.6°KW Spec. Inj. duration 3-8 °Ck.
406.7 mg/str MAF (actual) 210-350
30.2 mg/str IQ via rpm(Torq) 47-51
1044.0 Actual intake press. 2100-2600
Vacuum issue!
Then again, If It's only happened once don't stress, No point looking for a problem when one doesn't exist!
Goes into limp if im boosting alot. Cant decide whether its going to boost or not. Im running a pd150 hybrid on a stage 1 map and a smic though. What do u mean by vaccum issue? Is it an easy fix? Or is it another new turbo:(
Vacuum issue = should have bought a Dyson.
I'd say it's likely to be the map then.
