Brake discS
Ok Thank you I will see if thay do them for my car hopefully thay do
The front ones will not, but the rear ones do.
All Fabia rear discs are the same diameter (232 mm). You will want 256mm front ones not 288 mm.
Ok I have emailed them to see if thay can do them for my car hopefully. Thank you
Standard Pagid discs and pads would cope on a remapped pd100 never mind standard power. Why waste your money? Bought my front and rears for £99 including delivery from euro car parts. Not had a problem with them at all and I've put a lot of heat in to them, hardly any brake fade. Really good bite from cold too.
