Can't decide what to do with tyres
Ok, its slight, I had to really look but I can see every two or three blocks is darker with no "line". I will get the fitter to check them for damage and get them onto the front. Need to watch the pennies!
  • Replies 54
  • Views 4.3k
  • james_19742000
    james_19742000
    REplace all 4 with Falkens, and then sell the two good rear ones, offset some of the cost and you will be happy knowing you have a full macthing set of new tyres :-) I have never had a problem with F
  • If the rears are still showing a healthy amount of tread why don't you just keep them and buy a pair of tyres to replace the worn out ones? If you find them too noisy just swap them over to the front
  • I rest my case
Even the dealer said to rotate the tyres when I complained about the noise.
Hoping the yoko's doesn't suffer as badly
Got 4 452s fitted yesterday, noticed the pressure warning went off just before home today, the tyres all look ok so reset it, I gather its due to a change of tyre and the wheels being on differant axles?
The new tyres will have a greater circumference than the old worn tyres.
That's what I was thinking but I only ever reset the warning once when I first got the car, must be due to the sudden change, it was when i went from 20 to 40. They seem much smoother and refind so far.
