ASR light
I've looked through the previous forum posts - if I've missed the answer to this question let me know.
When I put the ignition on the ASR light illuminates and goes off when I start the engine. 4.8 miles later ( it doesn't seem to be a time issue only a distance covered one) the light comes back on - this happens every time the engine is turned off/on. The ASR system works really well so I'm not worried especially but is there a way to sort this out? A local garage checked it with their computer and couldn't find a problem and the disks hav been replaced.
Any suggestions guys?
Edited by davidt5120
You're definitely sure it doesn't happen after 10 minutes?
Get it scanned properly, your local garage may only have a generic engine scanner which probably won't be able to to do your ABS module. Sounds like a similar issue a mate of mine had on his 307, which was a faulty ABS sensor.
I always thought the light came on after 6 miles or so. Since you asked the question about "You're definitely sure it doesn't happen after 10 minutes? I checked again over the course of a couple of days and guess what - the only consistent factor is that it is pretty well bang on 10 minutes every time.
So thanks for asking the question - the answer is yes - it is after 10 minutes. So what does that tell me?
DFM signal wire to the alternator is broken and/or corroded.
Have a search, well covered.
I love this forum - does anyone happen to know the rating of this wire so I can go buy some
It's not carrying any current so nothing beefy.
I used some speaker/bell wire. Been fine since doing mine about 12 months ago.
Phil
Thanks - off shopping tomorrow followed by a bit of grovelling under the car
You sure you didn't just accidentally switch it off? ;)
Ddefinitely didn't switch it off - except when I tried to see if that made any difference to the on/off time
