Skoda Fabia VRS Intercooler Help!
Hi guys ,
been offered a universal intercooler with the following sizes
780x305x76
still waiting on pictures
The guy selling it says he has contaced jabba motorsport and they have said it will fit but i want to check with you guys first
Anything will fit, you just have to make it fit if it's not designed specifically for the fabia.
That is rather large. It won't fit without a large amount of faffing and cutting of the bumper bar.
Ok guys next question! Will the intercooler cause a lot of lag? I've been told this intercooler is the same as a focus st which some fabia owners run? Just don't want to waste my money on this without knowing it will work
It may cause a bit more lag, but are you eventually getting a new hybrid or big turbo and map to go with this? If so the lag wont be as noticable as you'll have more torque. Also I believe the longer the pipe runs/larger diameter the pipes are the more lag there is? So it depends on how its made up.
TBH after seeing some of the cars Jabba have produced, if they say it will fit/work then it will do :)
