Coilovers on! And Couldnt be happier - Pics
thankyou mate, old skodas never die they just get lower
  • Replies 61
  • Views 7k
Give ya a month till you need a new sump lol
I did plenty of coiled setups on the mk2/3's and was a pretty simple job, top mount bolts under engine bay and again the same in the boot, then one on the rear shocks holding it to the rear beam and fronts had two holding them onto the hubs, really straightforward. Is it as simple on these? I had a look at doing it on a friends 2005 passant and had to walk away, too much twisting and pulling things apart? Are the Octavia's pretty simple like mentioned above?
Or broken for parts :(
Stupid autocorrect.........
Pretty straighforward yes.
Rears can be done in an hour or so if the bolts all co-operate. Fronts a bit longer. :)
http://noahlh.com/car/coilover_howto/
fronts have top mount bolt, once free of car next nut retaining bearing etc is tricky, i ground flat sides into one shock shaft to get a spanner on it.
Rear is too bolts holding a mount into body under wheel arch, once mount is out, there is a nut in that to release strut. pretty basic but different
NEVER :sweat:
ive got my wits about me haha
Edited by Lofty79
Taaa!
I think I'd try it if there was a good guide for doing it on the vRS.
It is really one of the easiest jobs to do on the car and being Golf MK4 platform parts are easy to get to and remove.
here is a few guides that is for Golf but same as our cars.
http://fortuneman.tripod.com/suspension/install.htm
Ignore some of the pics that refere to the HR coilovers as the Weitecs, KW, JOM coilover are more simple to install as well and need no special tools really.
Yep the Octy which is Golf MK4 platform is not much different to Mk3 golf all similar set up
Are there any other parts worthy of upgrading/replacing when you're putting in coilovers?
strut top bearings, and having spare bolts.
Rear arb while you're under there too lol
Sent from my Galaxy S2 not a Crapple!
here come the money suggestions, there is no end to mods here
lol... I was just thinking things like bushes, or stuff like that.
But since its been mentioned, do you save a lot of time fitting the RARB while fitting coilovers?
just a good handling mod really. stuff thats really worth changing (necessity) top mounts and bearings
These shots gives you a idea of the part around the rear and front suspension
These are the extra parts I purchased below when I first fitted Weitec coilovers. You do not have to get these and you can reuse your old parts but I always get new to save any issues or broken snapped bolts etc.
These parts are all the parts I purchased from VW as they are the same parts(only went to VW as they are closer than Skoda to me) but that is your choice. Even Seat and Audi are the same(although only VW will sell you the Hub spreader tool, don't ask me why? )
Front Suspension
Inner Suspension strut nut x1 part# 1H0412365A
Lower strut mounting bolt 18mm x2 part# N10 207 803(bolts through the hub)
Lower strut mounting nut 18mm x2 part# N10 106 402
Hub Strut Spreader X1 3424
Rear Suspension
Upper shock mounting bolt 16mm X4 part# N90 648 401
Lower shock bolt 16mm x2 part# N90 517 304
Lower shock nut 16mm x2 part# N10 286 110
Then this lot came from a motor factor to save cost.
Front Suspension
Part Quant. Part No.
Strut Top Bearing x2 1J0-412-249 (GSF P/N 45737A)
Strut Top Mount x2 1J0-412-331C (GSF P/N 45736)
Also I went for doing the ARB links as one of mine was bad. Again purchased from GSF
RH Anti Roll Bar Link 42274N (IJ0-411-316D)
LH Anti Roll Bar Link 42274M (IJ0-411-316D)
Looks wicked mate :)
cheers dude, did you get your camber sorted? saw your thread, and you gave up last i read
Someone say camber? glad u got it sorted Lofty :)
cheers mate, hated it from the second corner, she fought me all the way.
Yeah..... Um :D the shims are now installed in the boot iirc lol
Ah well, if your not that way inclined, and dont do many miles you can just save while she is in her wee house and get someone in to do em. Has that car finished its first set of tyres yet?
has yours gone bouncy with it this low? mine has but im running the standard 17 inch wheels so think im lower than yours. My tyres just tuck under the arches a little bit
