Coilovers on! And Couldnt be happier - Pics
these are only 2/3 down, so yours prob wont need be all way down. Thanks alot, im very pleased with this mod, best thing ive done i think.
If It Ain't Rubbin', You Ain't Dubbin'
That is all.
  • Replies 61
  • Views 7.3k
has yours gone bouncy with it this low? mine has but im running the standard 17 inch wheels so think im lower than yours. My tyres just tuck under the arches a little bit
Mine are tucked in too, and im on 17's, bouncy only on the big bumps, but not desperate. Otherwise a noticeably stiffer ride, but no porpoising or repeated bounces.I think we must be running similar height, yours being vrs though will appear lower with that bumper i would think. A friend of mine has a standard octy so im gonna measure difference from centre cap to arch
That is all.
Oh and it IS rubbin :hi:
i just wound the suspension up by 8mm on the threads, which didnt adjust height much but improved ride by a country mile, it must have been resting on the stops just a little, now its still slammed but with a great driveability joms/pro sport have just gone up in my estimation again
Comparison pic??
Sounds like you should just junk the lot and fit rubber cones out of a mini lol
Sent from my Galaxy S2 not a Crapple!
Comparison pic??
It actually looks tha same about 6mm up and no one can see the difference, still looks slammed and cos its actually using more spring than stops now its working really well. Measured it against a neighbours octy and its 65mm lower than his
You've sold the JOM's pretty well on here, but I don't think they're suitable for the vRS, correct?
Not sure mate, if you buy a set for a vrs I'm sure they would be fine but mine are for standard and work very well, they don't have the mount on the shock for the drop links the vrs has, mine mount on the wishbone. I'm sure if you search a set of joms for vrs they will be around
Well after a few days I maintain my happiness with my purchase, lifting it to a 60-65mm drop has made all difference, and still get comments about how low it is. Wife came out for a drive today and we covered 120 miles, she said it feels a bit stiffer, and there was only one point on a dual carriage way that there was a bump that made us go "oooooph" and it still didnt wake the bearn'.
Best purchase I have made for my car (and now an americanism) period.
im winding mine back up as soon as the weather improves. my wheels can come out the arch a little as i just need to remove the bounciness! thanks for your updates
basically, i wound it up so there was 18 threads showing under rings
