turbo connector size (air out)
I need a forge adapter to allow me to fit a silicone hose onto the turbo but due to the utter crap weather icant take it off to measure it. I need to know the size of the metal connector that goes into the outlet on the turbo, itl either be 60mm, 63mm or 68mm.
Tom
i need to know the size of this aswel!
I have a pd150 turbo at home which is the same core as the 130 but im away for the weekend - will measure when im back if you dont have an answer by then!
ive had another look over the car today and ive got a split in the air intake from the air filter to the turbo in the little rubber reducer. ill get a new one ordered 2morow and then time to get the car mapped! :D
Did you get any symptoms for that vrsiain? Whooshing noises?!
Whooshing noises!? Mothers had to keep hold of the children so they wasent sucked up lol. It makes the loudest boost leak whooshing noise you could ever imagine!
Sent from my X10i using Tapatalk 2
For reference for everyone:
If fixed my intake pipe and found a split in a boost pipe aswel :( so ive used some black tape for now while i order some new boost pipes. Just have to take it easy!
What size is that turbo outlet pipe then? I can't see the picture correctly and i need to get one ordered as my boost pipe is split and keeps popping off now aswel!
Never mind, I rang forge and it's 51mm
