1.4 mpi engine swap
Hi, my MK1 2000 model ATZ engine code Fabia 8 valve died recently due to head gasket failure, which in itself is not too bad,it's just that it got so hot the oil started to boil so I am not sure whether the bottom end is damaged also.
In light of this I was thinking of replacing the engine with a lower mileage used item. I am not sure about the compatibility of some of the ones I have seen for sale as they
appear to look the same as mine but have different engine codes such as AQW or AME.
I am assuming if I used my original throttle body & transferred it over to the replacement unit all would be well, or is there
anything else that should be done.
Better still does anyone think I might be lucky & get away with just a head gasket.
According to the Skoda engine Workshop manual I have, the engines AQW and ATZ are technically (on paper at least) the same, except AQW incorporated EU-3-DDK/EU-4 emission regs whereas ATZ only covered the D4 emissions standard
This was because ATZ was produced between 01/11/1999 & 31/07/2000 and AQW was produced between 01/08/2000 & 31/03/2003.
So long story short, i dont think many of the parts are different.
Thanks for the info. Would I be right in assuming I could get away with an AQW providing
I used my original ecu/throttle body set up. I'm guessing that if I didn't then the the car wouldn't
run correctly because of the difference in the way mine & the later ones are programmed.
Any thoughts on the subject would be greatly appreciated.
Edited by nickg65
