help choosing which suspension
as title says ive looked through the forum and still cant decide what suspension set up to go for on my vrs, i have thought about coilovers and springs and dampers.
i do alot of driving on country roads and often have 3 passengers, so i thought the coilovers would be too bouncy.
i do want the car to sit lower but dont want to be bounced about everywhere.
any help would be appreciated cheers phil
Edited by Phil_15
Springs on the stock dampers seem very bouncy although coilovers are more 'firm' than bouncy mate..go for coilovers you wont regret it :)
For country roads and 4 up, I would stick with what you've got. If you want to improve the cars handling, then fit a rear arb.
thanks guys, do the rear anti roll bars make that much difference, i want to keep stock suspention but ive always had lowered cars
If you don't want coil-overs, what about Koni FSDs? If you want to lower then use Eibach springs.
i have thought about ap suspention kits
Options...
1) Springs plus dampers or coilovers. For a decent kit you're looking at £500+ + fitting unless you can find a group buy including fitting.
2) Rear ARB - Yes it makes that much of a difference. It's the cheapest and easiest to fit/reverse and the single most effective change.
3) Fit slightly larger tyres. Go to 205/50 from 205/45 to improve the ride.
I wouldn't want cheap coilovers on rougher roads. Particularly because that implies a reasonable ride height unless you want to be scraping the undertray on stuff.
Though I had a scary moment a couple of months back with a large stone in the road. I'm only -25mm on Eibachs but that plus the camber properly bounced it around under the car.
J.
