wheels
hi all,not been on here for a while,busy with other projects,still got my pick-up and its been running fine over the last two years,passing both mot with no problems,ive been offered some volkswagen lupo alloy wheels but not to sure if they will fit,they are four stud....anyone done this swap ?
Should do, ask what the PCD is from the seller, just to be sure. Should be 100mm between the centres of the stud holes.
they are 100mm pcd :happy: .i think they will fit but nice to have a second opinion....also they are 14" instead of 13`s....always thought 13`s look a bit small and this will also improve ground clearence.....ive bottomed out a few times when on rough ground .
Assuming you are on 165/70 x 13 now..
If the Lupo tyres are 185/55 x 14 isn't the overall wheel/tyre diameter marginally less? So no improvement in ground clearance I'm afraid.
185/60 would give you 16mm more diameter which is probably only about 8mm on ride height.
thats a good point juan27...iam not sure of the tyre sizes...iam going to have a look at the wheels on friday...i`ll let you know how i get on :blush:
pcd is the diameter of a circle that runs through the centres of the stud holes
Did you get the disc pic?
Edited by rolo
If the pick ups a felicia veedub wheels have same pcd and centre bore. The only problem could be the offset. If its not correct think somewhere between 35 to 40 then the inner rim may catch on the track rod end at the front the rears will be fine. Some spacers and longers studs on the front will cure any offset problem but do get the correct hubcentric spacers. As for tyres, I did run 185/60 14 which were fine and you will get a few mills extra clearance. It does feel better to drive on 175/60 14s though. If its clearance at the front the shocks may be knackered. I've got a tractor engined felly hatch and it used to bottom out frequently at the front until I put on some new shocks.
hi
thanks for that yorkyscott...yes it is a felicia,ive missed out on the lupo wheels and now looking at 7spoke (i think) golf wheels.these sell like hot cakes second hand...ill have to be quick :happy:
any wheels 4x100 pcd will fiit but you need to check et mine are 16s on 185 50 16 and a et40 7j but remember after market one's need spigot rings
here is a link
http://www.wheelfitm... (1994 - 2000)/
thanks for that link,very useful.......off set is the one i was`nt sure of....38 on the felicia same as golfs and lupos....local vw breaker has a set of lupo 5 spoke alloys with good tyres on ebay..£100 start price no bids ending in a couple of days, might make a bid and see how it goes........dont want to pay much more than £100
no problem happy to help
  • 4 months later...
So....thinking of getting some 14s to clear a proposed front brake upgrade as detailed on here.
Assuming its a 6J ET38 (Golf Mk2 Wheels) would 175/60s or 185/60s be best?
185/60/14, thats the standard tyre size for felicias with 14" wheels
