Trevorb33's Race blue mk2 vrs, now for sale :(
Quick vid of exhaust
  • Replies 167
  • Views 24k
My mrs thinks i am sad watching that lol
Exhaust sounds fantastic mate :)
Excellent progress and a belated congratulations on your new job :)
Fitted some polybush console bushes, very good quality very impressed, my old ones weren't too bad but would have probably been advised when mots due next month so thought I'd change them, no increased vibes or anything, had some old consoles I cleaned up so had these already fitted in so was just a case of unbolting and putting these on
Did you have to remove the lower arms to fit these? When i had my 4 wheel alignment done i was shown the movement in the standard bush,quite fancy doing this mod on mine if it improves steering feel etc.
Nope can be done in situ, there's enough movement in the arm to pull the bush down and slide it off, needs a bit of wd on it as they sometimes stick on, should improve feel and be abit more stable cornering, damn site cheaper then the anti lift kits,
more pics
Just got my new grill this evening
Looks great mate :)
Will deffo do this mod if i get mine,hated the chrome grill on my mk1 vrs..Did you buy this surround or have it painted mate???
Someone on here was selling one luckily in same colour
An update on the bushes now I've done a few miles, does make the front end feel more solid, I have the dogbone insert too but traction when pulling away seems to have improved a little too, there's a noticeable difference when going up and down speedbumps not a harsh feeling but more of a solid one,
Suppose I should do a quick spec list before I lose track of what I've done.
Engine wise
Forge BOV spacer
Revision D divertor valve
BSH stage 1 PCV fix
Neuspeed P Flow
ECS red coilpacks
Black coolant and washer bottle caps
Milltek 2.75 Inch non res Cat back
Pre cat removed from downpipe
Suspension
H&R -50mm springs
Koni adjustable Yellow shocks set to medium
Polybush front console bushes
Power flex Dogbone Insert
Exterior
Factory xenons
Diagem Indicator Bulbs front and rear
Superskoda led number plate bulbs
Osram Front 4k sidelights
Colour coded front grill
Superskoda Honeycomb Front Bonnet grill and lower bumper grills
Facelift Rear Lights
De vrs'd front and rear
Interior
Led front and rear interior courtesy light bulbs
Alpine headunit with iPod out/USB etc
Alpine 12" type R sub and Alpine mono amp
That's about all I think
Very nice mk2 :)
Decided to see what the old bonnet grill looked like with the superskoda bottom grill, I think I prefer it to the complete honeycomb front, remind me of the fl front end with honeycomb lower grill and slatted bonnet grill, thoughts?
Really not a fan of the honeycomb grills but it does look better with only the bottom one fitted. But at the same time kinda looks a little odd!
I agree does look better that's how the new ones are with honeycomb at the bottom and slats for the bonnet grill as standard
that does look smart! better than standard but not OTT :)
Like the combination Trev. Plus the fact you can open the bonnet properly with the std slat grille :)
How much were the Polybush bushes? Bushes are still on my to-do list.
Got some console and front ARB polybushes my self over 2 months ago not got them fitted yet lol, along with rear brake pads, oil and filter, air filter and gearbox oil!
Grill looks great man :)
They retail about £54 so really good value, easy if you have them already pressed in to mounts then it's just three bolts out and in
They are well worth doing make a significant difference, I need to do the wishbone bushes now and start polybushing rear :)
Got some new wheels coming end of the week should look sweet :)
Thanks. Where's best to get them Trev?
Can get them through shark or eBay etc
New wheels are here, going on tommorrow :)
Nice! 18x8? should be around 9kg or so?
