4x4 rear brakes
ok so my 4x4 needs a new rear caliper as its rubbish and i might as well do the discs while im there i understand the vrs discs can be used, 256 vented?
are the just bolt on or does the caliper need moving up ?
also where or what models can i take rear callipers from, i was going to use r32 stuff but cant find any at the moment and i sold my set a while ago :(
cheers guys
Edited by boomsly
Straight swap
Nearly all the 180ps+ cars came with vented rears iirc
vRS has them for example
so vrs rear callipers are bolt on, and the discs will aswell, if so that was easy!
The only PITA part is bleeding the brakes
excellent, many thanks for that, now off to find some rear vrs brakes :D
Edited by STSKODA
think the tt has 256mm rears, certainly the 225 models do.
  • 5 months later...
to drag this up again, will anniversary mk4 256 stuff fit on? seen a set of them up recently
Buy some new/recon rear calipers, do the job once and forget!
Seizing is a common issue & best replaced with new.
For bleeding them get yourself an eezibleed then it takes 0 effort to bleed the brakes.
direct fit
You need the caliper and the carrier
direct fit
top man, you are the go to guy for the 4x4!
messaging him now many thanks
  • 3 months later...
Ok, so I took my calipers and carriers off my vrs. Had them refurbed and painted shiny red. I come to fit them on my 4x4 and the discs (New, mintex) dont line up with the 'slot' in the carrier??? It looks like a spacer behind the disc would fix :0/
I'm guessing the discs I got (vrs) are either wrong or not a direct swap (thought they were). I have 'adjusted' the stone guard so it clears (clutching at straws). Are vrs and tt/r32 discs different 'offsets'?
Confused.com :0(
Stone guard has to come off - fouls things up a treat iirc
Stone guard has been 'adjusted'... The discs just plain don't fit the carrier. Not a straight swap :0(
No the 2WD carriers are different. Calipers are the same.
You should have got audi tt 4wd rear caliper / carriers
I already had vrs kit. Will have to check Etka to see if I can get the setup working.
intriguing
My rear calipers where sold to me as coming off an Anni golf
I had been assured at the time that all rear vented setups where the same
fitted without issue (apart from splash guard)
Use mintex/pagid disks as sold for vrs and lcr
maybe they didn't really come from a anni - I just bought at face value and fitted
I do have some 100% genuine vrs rears sitting around, I'll have to go have a comparison
As said the calipers are the same, the carriers aren't.
Yup the 4wd and 2wd use different carriers
So you can fit the 4wd caliper / carrier with spacers
I think we might be getting confused here
Just to be clear
No spacers should be required
We're not talking about using the single unvented disk caliper either (they go in the bin)
The part number for a 4motion/S3 carrier is 8N0 615 425 B
Just to be clear
So why does awesome gti sell a 6mm spacer to fit 4wd 256mm vented brakes to a 2wd car then? If no spacer is required? Seems a bit strange for a company to make something up that isn't required?
Im not talking about the 232 rubbish - unless if completely misread the thread?
Unless your talking about replacing a knackered 256 caliper with one from another model, so just changing calipers and using existing carriers
I think thats where the confusion is coming in as calipers are the same just the carriers differ on the 2wd to 4wd
- unless if completely misread the thread? ...
:giggle:  ok, press rewind - a little background
The Octavia mk1 4x4 comes from factory with a single unvented 256mm disk, which gets very hot
The primary purpose of this upgrade is to get the double (vented) 256mm x 20mm disk onto the Octy 4x4
The stock 4x4 rear caliper is too narrow to take the wider vented disk (hence why to ditch it - it has little resell value)
So the wider caliper is required, as found on models like the vrs, s3, r32, tt, lcr, etc, etc
At the time I had been told  that any vented rear setup would directly fit.
I went to ebay and bought a set of vented rears calipers, carriers and disks - allegedly from an Anniversary Edition Golf GTI
Fitted without issue - so I naturallly assumed the info I'd been given was correct (this was 3+yrs ago now)
It appears now the 2wd cars use a different rear caliper carrier
As we're talking about upgrading a 4x4 here, the link to the adapter spacer is irrelevant
In Summary
For an Octy 4x4 owner, upgrade rear brakes specifically from a S3, R32 or TT
( and I'm going to try to see what carrier's I've got on my car - if they really came of an anni - well guess that'll be more confusion  :rofl:  )
