New Springs fitting
£250 for new lowering springs fitting and wheel aligament?! Does it really cost that much ?
2hrs labour £60 per hour
springs what £100?
allignment £50
total £270 so yes! Its labour that gets you
Edited by Lofty79
Sounds like a good deal.. Depending on what springs are being fitted etc... :)
sorry this is fitting only !!! without springs !!!
then its a little overpriced i would say £200 tops
I got mine fitted by a vw indy for €150 (£125)
Seems a little steep. cost £100 on my last car.
I've been told is 1h per wheel plus 1h "is something went wrong" :think: £39 per/h plus £55 wheel alignment.
rubbish! rears took me 15 minutes to do both 30 mins if something goes wrong. thats alot of doe
Sorry for going off topic.
Dallan, what VW indy do you use ??
Thats a well guarded secret :p
You could fit the rear springs yourself and get the garage to fit the fronts. Im sure its just a case of jacking up the car, whip the old rear springs out and install new
if you wanna do it without compressors, youll need to undo the bottom of the shocks on both sides and jack them up equally, or arb will restrict a one side drop
By the book it's about 3 hours, so they're hardly ripping you.
On the front, don't forget that they'll be taking the dampers out. To be honest when the labour costs more than the economy dampers, you have to say that it might make sense to put two new VAG eco dampers in the front anyway.
Worth replacing dampers at Same time .Car will be like tigger without .£200 for mine fitting everything and 4wa
Did mine yesterday took a while fronts are a pita backs piece of cake also factor in new top mounts for the front if yours has done some miles (eurocarparts were cheapest £43 inc vat for both) one of mine fell apart.
Neil @ Carbon Motive quotes £150 to fit normally as a guide.
Don't forget to use your 25% briskoda discount if buying your top mounts from ECP
Now all fitted!!! Done rear springs on my own and even for un-experience person like me J this was around 1h for both. Got front fitted by local garage £60 . Now will drive it for a few days to allow them to settle and four wheel alignment to be done (£55).
Car lowered with H&R 35 mm springs J looks stunning already
