removing front emblem
As title how do you remove it? I bought a replacement one any give me a quick how to?
Try and get fishing wire behind it and saw through. There is 2 plastic lugs behind aswell.
What do you with the lugs?
Screw driver or butter knife and rip it off simple with a bit of heat from a heat gun/ hair dryer and it be fine
The lugs are for locating the badge when your putting it on. They are moulded to the underside of the badge.
I took the whole silver sorround out so i could work on it off the car, i got some glue remover and let it soke into the glue.
Then heated slightly and it pulled off easy
