Moo-ing rear brakes
Right my rear brakes have started making a moo when driving forward between 5 and 30 mph and its getting annoying. camber shims are fitted. i have 256mm rear brakes off an octavia vrs. can anyone tell me the part numbers for the fabia and octavia rear brake moo kit they get from a dealer.
which to use?
jake
I too have the 256mm rears.
If you mean the rubber bush kit then don't bother with it IMO. They are not cheap!
I have that kit and the rear brakes still make a terrible noise when wet and reversing. I intend to swap for helper springs at some point.
Could be worth putting a slight chamfer on the leading edges of the pads. I've used that to get rid of noises on other cars.
I also take the edge off new pads when fitting them to reduce noise.
hahaha i know ive tried that. need to take it all off again and have another play i think. if anyone has the part numbers that would be great.
Mine rubs on the o/s/r when they're really hot - is this what you mean?
