Felicia won't start
Hi hoping someone can help me went to start car tonight and it ran then stopped toyed to bump it off and still would not start it's a 2000 1.3 mpi felicia not had this problem before also when I go to start it again can here pump prim up will run then stop after a 2nd or too any advice much appreciated si
Is it really lumpy when it does start? Hows your ignition systems, plugs, coils, battery etc..
It's not really running just uses what petrol in carb mine has the coil pack so no leads battery went abit flat with me trying to start it but even when I tried to bump start it it did not even try so stuck at mo
Take a spark plug out and see if its wet.. Could be flooded.. How was it running before it refused to start?
It was running fine no problems that I noticed and will check spark plugs in morning cheers
Sounds like an immobiliser problem, has the key been apart lately?
If it was an imobiliser drama, I would imagine it wouldnt of started the first time then die, it would just be completely unresponsive when you turn the key.. No cranking or anything.
It does not have one only a light in the key fob so will have to do some investigation work in morning hope it nowt serious
Crank sensor?
Ok cheers will try looking at that today
No, the immobiliser will allow the car to start, then it will cut out a few seconds later.
Ok had a look and think it might be the fuel pump no fuel coming to the filter blown back down pipe and can hear it coming back into tank will let you all know what happens anybody know a breakers in or near Huddersfield cheers
again sounds like immobiliser issue. from past experience. first thing to try is the spare key.
The immo cuts the fuel pump after a few seconds.
also your car does not have a carb.
Edited by J242
me too,immo,do you have a code reader ?
The key fob just looks to have a light in it nothing else cheers
And yeah sorry throttle body
If you have a spare key try that, certainly sounds like an immobiliser fault.
J242 thanks for the suggestion found the problem my lad dropped the keys and the chip had fallen out off the key fob so been outside looking with a torch and found it looks like it been run over a few times hopefully it still works if not use spare and get my mate to cut mean other thanks again for the advice :)
Ok I'd like to thank you all for your quick replies and pointing me in the wright direction it was the immo as you all said car is now back together and running great thanks again :)
Good news :)
