Anybody got or had a similar fault ?
Since owning my Vrs I've noticed when I open the drivers door the interior light and the puddle light in the door doesent come on ive checked the bulbs and they are fine.
However when I open the passenger door the puddle light and interior light come on
I haven't investigated it past checking the bulbs
Any ideas would be appreciated :)
The terminals on the light itself were quite corroded on one of mine. Remove the plug and see if there's any green snot...
Thanks for the quick reply I shall have a look after work :)
Drivers door lock microswitch.
Mine has always been like it. 3 options. Replace entire lock. Buy an aftermarket microswitch and solder it into the lock mechanism. Live with it.
Door switch as said, be careful not to lock your keys inside lol!
I went with replacing the switch with a maplins switch, fiddly bugger of a job but not crazy difficult, there's a good guide on here man ;)
Brilliant cheers fiddley electrics isn't so much of an issue for me as my job I'm allways working on pcbs and electronics but car electronics can't be much more difficult from plasma cutters and welders :)
Does anyone have the link handy?
Cheers again guys
Cheers again guys
look in the guides section, it will be easy for you to repair considering what you do...as long as you an get it out!:>
Yeah I remember when I was sound deadning my doors a couple of weeks ago Its quite tight in there with big hands :)
the electrical side of things is really easy it's just soldering 2 wires, the difficult bit for me was getting the switch in exactely the right position before crewing in place, and as said the removal/refit is tight
