Sunroof trim
Has anyone who has the sunroof fitted had any problems with the trim around it?
The bit between the two sunroofs is finished with a rectangular bit of plastic, however mine seems to have snapped off on one of the ends. I'm guessing this wouldn't be a part Skoda could get hold of, especially as the sunroofs are not actually made by Skoda themselves.
Will try and get a picture later, however has anyone experienced this?
Got one on mine, but it has been stuck at dealers since my first drive!
However, regardless of who actually makes the sunroof, if it has a fault then skoda should put it right. The picture will help to understand the actual problem you are facing though, do you mean the plastic light screen that slides under the sunroof to cover it from the inside?
Andy
hi so your sunroof is a after market one or factory fitted ?
I presume factory fitted
