sudden loss of power- no warning lights
Hi- I'm a new owner of a diesel- its an octavia mk1 1.9tdi elegance estate. Accelerating on the motorway out of a 50mph controlled area and the car suddenly went sluggish- couldn't get it above 70. It drove home fine but it feels more like driving a van. Any advice what to look for?
Thanks.
well limp mode is mainly caused by a faulty maf or a sticky turbo, carb clean the maf, if still the same problem bomb it up a hill in 3'rd gear, if the car goes into limp mode chances are you have sticky turbo vanes, might be worth a read but search for mr muscle turbo treatment an other member here lofty79 has done a little guide, i had the same problem with my old tdi, done this to my current tdi and no limp mode under heavy load so it does work
Yeah sticky vanes. search "mr muscle vnt turbo treatment a guide of sorts" it'll be near the top, and was started by me. Sorry can't put up a link on my phone
Oh and if you switch ignition off and back on again you will have boost back until it next does it. It's over boosting, the actuater rod and vanes get stuck so you get boost but when you ask more of it and it can't provide it - limp mode. Positive deviation I think the fault code reads. Mr muscle will sort it, and give you back some power aswell. Follow the guide and you can't go wrong - did yet another last week that 17 and counting
really appreciate that- will try it out tomorrow. thanks. :-)
I just gave it a read through. Although it isn't the trickiest of jobs, I'm not one for risking doing unnecessary damage and I'm a bit clumsy. Have you any views on the forte turbo cleaner- do you know anyone else who tried it? I'd rather spend fifteen quid (if it works) than risk making a big mess from inexperience.
Forte has worked for some, not for all. But it doesn't last too long before it bungs up again. Your choice buddy you might get results
ok thanks. will probably pluck up the courage to mr muscle it.
It's ok - I don't like the idea of faffing with feeding tubes down my EGR hole to the turbo either - so it's car up tomorrow and whilst it's in bits do it directly from the downpipe end whilst it's up as a precautionary measure ;)
With regards to the M Muscle treatment I see from previous posts that it works but where does the crap from the turbo end up ? Surely not into the particulate filter where it may stick? Not a criticism just interested to know....................
No particulate filter on cars of this age.... There is a cat, but when you look at a lot of diesels can can generate black sooy exhaust all the time, so a small release from the turbo clean can't be that bad.
As predicted, the car was fine when starting up again today- more than likely we've got the correct problem. Had a look underneath and I fancy having a go with the oven cleaner. I worry a little bit about not getting the pipe in the right place- any disastrous consequences if I do, or will it just not work properly?
its very hard on your engine to get it in wrong place, if you can get it into a cylinder i would be suspicious of you being Uri Geller
ok, cool. Thought I read a warning about this on the original thread. It seems to be inevitable then- just have to get the materials and I'm having a go. Will try and remember to add the results to your original for others to see- it really helped me to know that it worked for others.
:happy:
Just done this, after a lot of deliberation. Worked a treat. Still stunned that it actually worked... Thanks. :happy:
of course it works. haha
