FK Sale
Would anybody happen to know if those coilovers fit the Vrs ?
fit...yes...
weighted for correctly...not so sure
Having a look and some parts on the site are weighted 1000 kg / 1070 kg, this is VRS weight isnt it?
My phone wont let me quote ... Oet do those coilovers take more or less weight ? As more weight wouldent be an issue due to my audio install
let me have a look again steven
cheers mate
cant see weight specified on those coilovers?
the vrs is 1000kg front 1070 rear
Tap the text that people have written, a Quote box will appear ;)
Dam shame they have nothing listed for the superb :(
What about looking for a passat John?
Same model underneath - just a thought ;)
The coilovers are for the tdi and non-vrs according to DPM who sells the same kit for £175:
http://www.dpmperfor...698-p-7712.html
bummer ... ah well ill save up for some proper ones :)
What would be the correct wheel bolts to use with 5mm spacers and standard wheels ?
There site isn't that clear, but the prices seems good lol.
does the passat also have the multi link suspension arms the same as the superb? i remember when we ( John being my dad ) took the wheels off the superb we hadnt came across that suspension set up before ...
good spot chris!
i cant work out how they are listing that setup for the diesel, when its heavier...
the vrs usually lists for these type of parts.
i think you can get away with your existing bolts (not that i am telling you you should, or order longer bolts accordingly. Anything over 5mm and you NEED to change bolts. Count how many winds you have, thinks you need soemthing like 8 or more..(check online).
