Si's disco off roader.
SNH
Love it!
Haha
Cheers
Desert again Sunday and only manage to break the cb aerial and split a water hose. Was a good day and its all fixed again now.
Few weeks off now while I get another door fitted and hopefully the weather will stay nice so I can get it painted. Also got some paint for the wheels and a steering guard I'm collecting
Picked up a steering guard yesterday so gave it a coat of paint (same colour as the wheels are going). Hopefully get it on later.
Also tested the NATO green will look like on the truck, it will eventually all be going this colour :)
Hopefully picking up a heavy duty tubular winch bumper later aswell :)
Now has a heavy duty tubular front bumper with recovery & jacking points
Also got some 10x15 wellers coming, need a refurb but were cheap and they'll allow me to fit 33x12.50x15 tyres :)
Edited by SNH
Dont say that It has got hi lift jack points on it :(
It looks a whole lot better now I've rollered it, it took me an hour if that. Shame it dropped a bit cold would've liked to have got it all covered in the 1st coat today.
I liked your old filter head better. This new one looks like a bad flow restriction.
An alternative is to get a 45 degree bend and run it up so it finishes in the gap between the light and the roof bar. Pointing backwards.
It will still flow better than your new ram-head and pointing backwards it will suck in less thrown mud and water.
Don't worry about ram air effects. They are are a fairy tale at legal speeds. If you can do 300km/h then it's worth considering.
Its a proper Southdown snorkel so can't see it being a bad flow, the old one let water into the filter and airbox as it was no good hence why it was swapped over. I'll spin it around when I'm offroading so no mud can get in but it catches on the end light so I'm restricted on movement.
Not boosting above 12psi, fins are damaged and the bearings are going
Oh right.
200tdi isn't it? get a new CHRA and throw it into your existing housings.
http://www.melett.com/turbo-parts/1-A-1060.html
Melett are guaranteed good, chinese CHRA's are dirt cheap. Just be careful if anyone is selling you an "upgrade" that it doesn't kill all low rpm response.
