Si's disco off roader.
Just be careful with lift blocks. If it's just under the springs, you can risk spring bind where the spring slams shut before the bottomout bumpers hit. This can rip off spring perches. You will likely also be at the limits of the stock brake lines on extension.
I'm running Konis for an 80 series landcruiser in the front, I have longer front bump-stops fitted (orange poly's from one of the UK suppliers) and these work nicely with the stock towers and 2" longer brake lines and 180lb/in springs about 420mm long each. I've got about 3" more downtravel than stock now and can get full compression and extension without bottoming the shock or letting the spring jump out.
  • Replies 130
  • Views 14.1k
  • Steering guard on Better pic of the NATO
  • Looks like someone has fitted a 300Tdi Engine cover to reduce the noise to your 200Tdi. I forgot to say, avoid Britpart for cheap parts. Most Land Rover people refer to them as S**tpart because the
  • Dead jealous!! Something I would love to get into one day when I have more time and less hobbies!
It is all poly bushed which was done during its rebuild, along with all new shock, springs and most suspension parts aswell. I've not looked at the brake lines (always to dark) but I assume these were lengthened when he did it as offroading was its purpose but I'll double check to make sure. :)
I won't be going to mental as the kids will be with me, so I'll see how it copes.
In the front radius arms poly bushes restrict the articulation. You'll get more movement and more traction with the OEM rubber bushings. I run polys in the radius arms and panhard rod myself, partly because I've got a real heavy diesel and partly to get back some road manners.
But first things first, test it gently in a dry area where you can easily get out to see what's happening without being up to your knees in mud. Then get out and have some fun.
You can always change the polybushes if required, as Red, Orange and Blue give varying stiffness which can be softer than OEM.
I found Orange a good compromise.
From what I noticed I think they are orange. I'll know more Saturday when we do the blocks and I've had a good look round it In daylight :)
These early nights suck!
Managed to get that water pipe fitted and fitted a new spare wheel carrier and mounted the spare :)
Sooo high :D
Sooo high :D
Needs MOAR HIGH'S :)
Tunes done!
Bonnet pins done!
Now onto the front blocks :)
Sooo high :D
Just like how my Fabia used to be :p
No more strap holding the bonnet down :)
That's looking good you'll be addicted once you get out in the mud had mine over 2 years now buttons to run and fix in 2 years its cost me about £100, a new battery being the big one everything else just peanuts like indicator relay etc here's mine
Daihatsu Fourtrak 2.8TD it's was an 7seater once upon a time lol
I like that :)
I did look at fourtracks and sj's but they weren't really big enough for what I wanted so settled on a disco.
Looking forward to getting it dirty today :)
A few pics from today which was awesome. Truck ran faultless and only got stuck twice, which was down to me wanting to go where no one else would :)
Bring on the next outing ;)
Wow, you are quick off your mark!
Lovin it, great pics :)
Double post.
Edited by SNH
Hopefully out again Sunday if we can find my mate another one. Unfortunately his took a bit of a beating Sunday and needs replacing :)
Did you manage to trash one Disco in the process ?!?
My trashed his, bent the chassis being towed out, smashed a front Caliper off, prop donut, and snapped a brake pipe :)
He's brought another one today so alls good.
The prop donut, okay. The rest ???
It obviously couldn't hack the pace :)
Tackled the stereo and electrical gremlin today!
Got the stereo sorted, had to run a perm live straight from the battery in the end as the wires are all butchered!
Fingers crossed I've sorted the gremlin aswel :)
Checked all earths and they seemed ok, noticed a broken wire on the alternator so fixed that and hopefully that's cured it. We shall see.
You have my commiserations. Stock wiring is the worst aspect of owning a landrover. Closely followed by previous owners who tried to fix factory problems in very bizarre ways.
Whatever you do, if you find two matching plugs under the dash that look like they fit together. NEVER, EVER connect them.
