'09 vrs tdi CR 170 fuel filter change. Help!
Hi. I've been doing a fair bit of reading up and scouring 'how-to' videos on YouTube before I pluck up the courage to perform what seems to be a very simple job. There are still a few grey areas though:
Do I really need to disconnect pipes? What fuel additive/cleaner is best to use?
Have I got the right filter? (I see there are three types)
Is there an easy way to prime the system or will simply filling up the filter before replacing the lid be enough? And so on...
It's a touchy subject, I need to make sure I'm not going to wreck the car by overlooking something.
If it is anything like the PD, the only way you can tell which filter you need is by removing it and having a look. Then keep the part number handy for next time. Or, have a look on any invoices for previous services.
I have never disconnected the pipes, just take the lid off carefully, and don't lever it off with a screwdriver as if you damage it you will need a new fuel filter housing, and possibly a Campbell as well if it leaks diesel all over the place.
When the new filter is in just top to Yeh brim with diesel and refit the lid.
That should have been cambelt, not a brand of tinned soup, auto correct on the phone strikes again!
Cheers Andy. So when you changed your filter, did you just crank the engine over a few times to get it going?
Yep, just make sure you have some diesel to hand to fill the filter housing up with after you have swapped the filter.
Put the top back on and it will fire up fine.
Assuming the CR has an electric lift pump in the tank like the PD you don't even need to fill the filter housing up with diesel.
Just put it all back together with the filter full of air. Then click the key on (without starting the engine) to make the warning lights come on and the electric lift pump run for a second, then click off. Repeat this 3 or 4 times. Then just start the engine as normal, as long as you let the lift pump run a few times before starting it is completely self bleeding. When I've done this on my PD it starts perfectly first time with no extended cranking or any hint of a misfire etc at all. I've used the same trick on Pug HDi's and it works on those too.
Good tip, I am so used to having to make sure you get as much air out as possible that I topped up out of habit.
The part number for mine was painted on the side of the filter housing (ufi). It was hard to see though but it was there.
Check, double check, triple check and then get the wife to take a look to make sure the gasket between the lid and the filter housing is secure and that you haven't loosened any of the feed or return pipes when you've held the lid out of the way.
Or this happens...
http://www.briskoda.net/forums/topic/258824-dead-vrs-pd170/
Cheers, Silver. That fills me with a world of confidence! Haha
There's no doubt I'll be checking everything a billion times, its the reason why I take forever to do anything! Ha
I need to be 100% sure the procedure is the same with the CR 170 as is with the PD.
Just found and uploaded Elsaweb onto my PC. Hopefully that'll dot the T's and cross the I's..! Thanks gents and/or ladies, I wasn't expecting much response to such a simple ask. I really appreciate it
Cheers. Yeah I found out a mate of mine had a trimmed down version on a disc and he let me copy it. It's exactly the same as the elsaweb site but you can go much much deeper. You can also tailor it to your specific model
Oops, double post. Sorry, smartphone issues!
If you havn't got VCDS don't go there...
Sent from my LT26i using Tapatalk 2
That was my main worry. From what I've recently found, the VCDS is brought up when the '09 CR concerned. Pants
*is concerned
It is needed to cycle the two pumps to prime the system otherwise it will not start.
It's heartbreaking that DIY filter changes aren't as simple as they used to be. I miss my mk2 Golf *sigh* haha
Has an interesting priming method if VCDS ain't easily accessible!
All Bosch CR systems are the same, if you check the VCDS owners list another member may help you.
Brilliant! Cheers for that. Very handy.
Sent from my HTC Desire HD A9191 using Tapatalk 2
