Doh! VRS playing up!
Having fun with my Fabia at the minute, it keeps losing engine coolant from the radiator, seems to be a common problem looking at some of the other threads.
Where is the best place to get an OEM rad from? Or are there uprated ones around which may do a better job?
Also the rear passenger caliper has seized up to top it all off. At least I can repaint them if they come off.....
Randomly the power steering stopped working yesterday but is absolutely fine today. The power steering light on the dash is also no longer lit.
Fabia's eh? :wall:
Bump
Check your power steering oil level mate, and i got my new rad from tps cardiff
TPS will do a rad but I imagine ecp will also do one.
Have you fitted helper springs to the rear calipers to stop them sticking? Quite a common fault and worth searching if you haven't.
Could be a low battery, the cold kills weak battery's so it's common to get powerd steering issues in winter. Also worth searching as Fabias have about 3 common faults with powerd steering.
