External temperature fault
I picked up an 01 Elegance 4x4 workhorse today and on the drive home I noticed the external temperature in the instrument panel fell to -12 degrees celcius, and switched to farenheit too, while the temperature in the climate control remained correct,
Are there 2 different sensors feeding info to both areas? If so, where is the 1 located for the temperature in the cluster? Would these symptoms be common?
Anyone?!
I know there is a temp sensor behind ns bumper grill
The lower grill? Aye, cheers. Just curious if there are 2 seperate ones as its strange that the 2 readings are different.
Thought they were same altho i might be wrong
I think there is only the one external temp sensor.
I know just one sensor behind the fron grille
The other temp sensor is part of the aircon system, iirc it's in the heater box where the fresh air/Evaporator flaps meet each other.
the sensor behind the grille only does the external temperature.
Anyone know a part number for the sensor in the grill?
