Torque settings
Hi
Does anybody no the torque for the wheel nuts & also the sump plug
Phil
Wheels 120Nm
Sump plug 25Nm
IIRC
Sent from my HTC Vision using Tapatalk 2
120Nm for the wheels....nooo way
??????? Why not
Normally 120nm - 140nm for a lot of cars
Yes way....
Manual quotes
Road wheels 120Nm or 89Ibs
Sump Plug 40Nm or 30Ibs
this is huge....I think I tight my nuts something like 40Nm
120 is quite easy to do with my torque wrench and easy to undo again with a breaker bar.
40 is way too low, you could do that with one hand.
If you go somewhere like kwikfit they normally seem to aim for 1200Nm or more if they get it with the gun.
Yes way....
Manual quotes
Haynes manual also says the same for the roadwheel bolts, not sure about the sump plug. I think I might avoid travelling in IulianE's car anytime soon :giggle:
me too :)
120nm it is then cheers for the advice
Just tighten them til they shear, then back them off half a turn. :D
The KwikFit approach. Actually I have to confess to nearly doing that when I changed the front pads on the then gf's fabia. I ended up torquing up the retaining bolts on the front calipers a bit too much.... I realised just in the nick of time and swapped the bolts over. Not sure which would have been worse - a caliper which might have fallen off, or a the fact she was driving around with no friction material and didn't seem to even notice.... :wonder:
