Fabia vRS mk1 lower dogbone mount with Superpro solid bush installed
I have this spare dogbone mount (gearbox one) for the fabia vRS mk1. Came from a seat ibiza FR with the same chassis.
It has a Superpro solid bush fitted (and run in) so performance should be great, whilst not having any severe vibrations.
It will need bolting to the plate which mounts on to the chassis, then simply fit to your car and retain your own mount to return to stock when desired.
£45 including P&P :thumbup:
Any questions, shout.
Shout!! is likely to fit the vRoomster??
Is this the 70k or the 80k bush?
Daz
Not sure. How do you tell? Not aware there were two types.
The part number is 2907 which I gather is the 70K bush. Assume this means its slightly less "vibrationey" than the 80k?
No idea on Vroomster to be honest. :(
hmmmmm........................about 99% certain it will.... :giggle: ......as the Roomster uses the same subframe as MKI Fabia.....which is the same as MKII Fabia.......
look at my post here...
http://www.briskoda....r-engine-mount/
Edited by fabdavrav
I'll buy it!!!!!
PM'd
Sorry - per my last post, I don't want to annoy anyone on fleabay, so leaving it on there. Someone messaged worried they thought the bush at the other end had been taken out. It has not. :) (Just a trick of the camera angle)
