Plastikote front grille question
Hi all
A couple of months ago I sprayed the chrome inner part of my front grille in matte black which I was very pleased with :)
Gave it a good 6 coats at least
Had to re do it again a month later as the odd stone chip took the paint off so I ended up with chrome bits all over it!
Took it off and did it again with a few more coats all over
Now it's back to the same look with chipped bits all over
I know I'm putting enough paint on but is there anything else i can do to try and prevent this?
Maybe lacquer?
I don't want to be taking my grille off every month to re spray it!
Cheers in advance
mine had 8 thick coats on and has been fine for 2 years, infact its still like the day it was done. Id say you arent putting enough on.
I painted mine, in about 5 months it's chipped twice. Tempted to get it carbon dipped!
Ok cheers
Vinyl wrap?
There's a difference between plasticote and plastidip, plastidip is quite hard wearing.
Maybe that's where I'm going wrong :/
plastidip cures like a vinyl and peels off when you no longer want it. . .
plastikote is a paint. . .did you key the chrome first?. . if not its gonna just chip off all the time.
That plasti kote stuff is crap mate! In my experience anyway :)
Ok time to order plastidip :)
Any links of best place to buy?
ebay or the UK plasti dip site :) theres VAT & shipping off their site though.
Thats a good point! Mines plasti dipped! Good luck mate.
What am I best doing with grille as it is now then with this plastikote on?
Sanding it first then use the plastidip?
I just sanded all the chrome back with with 120 grit wet and dry, good wash with panel wipe, then used a coat of primer, 3 good coats of cheap satin black and couple of coats of lacquer!
All good 5 months later!
I know all could change over this cold spell but so far so good!!!
Need to get a good key and clean to start with if painting!!
Hope this helps
