fabia 1.9tdi intermitant juddering and hesitation
Hello,
i have got a fabia 1.9tdi (104,000 miles) that has started to judder when accelerating in all gears, it also seems to lose some power / hesitate when accelerating.
At the moment the problem is very intermittent and when the juddering occurs if I turn the engine off and on it seems to clear the problem and the car runs fine.
Also the judder does not occur from cold and only happens if I have driven the car for 5-10 minutes and then get stuck in traffic before going on to faster roads again.
I would appreciate your thoughts on this as it is starting to concern me.
Thanks for you help in advance
Neil
Hello Lofty79,
Thanks for the reply, I will try cleaning the engine / turbo as described. I am not a very experienced mechanic but this seems fairly straight forward. I think I will also replace the fuel filter and air filter at the same time as I am not sure when this was last done.
In relation to the flywheel failure, I think that at the moment the issue is very intermittent (only happend twice in the last 3 weeks) and as I can stop it from happening simply by turning the engine off and on, do you think that the issue might be electrical i.e. a sensor not working properly?
Neil
ah i see, the juddering you speak of, could it be described as a misfire???
or is it kangarooing?
