Hello from Livingston... and Help!
Just registered as I've often looked to Briskoda for answers in the past.
I have a 2004 Fabia 1.2, it is excellent, and has only now after 88000 miles brought me to a halt!
I am needing a new battery it's true, I car share and while it's fine during the weeks I drive it's been needing jump started this winter whenever it's been sitting for the other guy's week. But today was... weird.
I jump started it, everything was normal, I left it ticking over while I put the leads away and closed up the other car and the house; then however it cut-out when I'd only moved half it's length and won't refire. It was turnbing over no problem but was showing no sign of catching at all. I have just replaced a coilpack last week, but again everything seemed back to normal before today.
Could there be a separate electrical issue that effects the ignition but not the starter?
Does it need some kind of reset after having a new coil?
I'm as certain as I can be that it died away rather than stalling.
The battery is questionable, but the engine was turning over very well and reconnecting the other car made no difference; I just don't understand.
Could I have fried the ECU?
Hope someone can help!
Best
Robin
Can a modern car be flooded? I think there was an unusal smell of fuel...
If you're in Livingston I could scan it with vcds for you, might show something up
Sent from my Nexus 7 using Tapatalk 2
