MPG dropped low (getting there slowly I think !)
i would have thought so yes
it may be a split too on the inside of a corner or something, not visible.
a hunt i think
  • Replies 71
  • Views 8k
  • also the sensor in the inlet mani next to throttle body, gets just as dirty as throttle body itself, may be worth cleaning this very gently with something
  • also the wiring to each of these, there may be a break or a short causing the intermittent nature and getting worse. Checked throroughly for boost leaks? Dump valve could also be to blame, the list n
  • Sorted the PCV valve and T piece. Fiddly but easy enough when get in too it. Hardest part was when my helper dropped a screwwdriver down under the passenger wheel arch (thanks Em) But this is how the
Hi Dave, have you checked the DV seal is holding? Have you checked that you have vacuum?
Personally I don't think your issue is with the pancake to intercooler pipe as the oil doesn't look wet. I ve replaced that pipe on a 1.8T AUQ before, in search of a cure for the dreaded 17705 code before, & your pic looks like normal build of grime to me. (17705 eventually turned out to be a dodgy value in the custom code map)
Edited by pauldazzle
Sounds like a leak within the pcv system, check the link for more info on fixing the problem.
http://nomads.eurodi...entilation-20vt
Edited by hillside
Yo Paul how you finding the snow out your way, I was over there 9am Friday, it was fun !!
Checked the dv, and tried an OE one just to be sure, all good
I'll have a read of this lot today, ain't had much time over the last few days due playing in snow !!
One thing I had noticed is my dipstick is rotten with oil residue ??
Which pipe is the common culprit under then??
oil pick up pipe could be foul.
could maybe benefit from a flush and a pick up pipe change
what do you mean by residue?? have you had your opil pressure light on?
Done that a while back, the yellow dipstick holder under the manifold is dirty on the outside around where all the PCV, SAI, pipes are
Thinking about this and reading about the PCV valve setup, could this be why it's using a bit of oil these days, pressure going the wrong way or summat similar.
could be, so many pipes and so much possibility for leaking, it could be causing oil loss and maybe knock on to the boost issues youve been having
sorry in previous i thought you were taking internally
Edited by Lofty79
Your right about too many pipes !!!
even ma tdi was over piped, i got rid of 90% its almost like they thought, there is a gap there, mmmmm, nuvver pipe? - yeah!
Replaced 4 for a friend of mine recently on gti 1.8t, s pipe y pipe and various other letter shaped pipe pieces
Oil residue around the dipstick is a sign of split pipework under the black manifold cover. Pretty much all the pipes under there are prone to splitting. S pipe is usually the 1st to go, & is difficult to spot as it's so tucked away. I have a spare in my garage if you need it Dave. Think I've got a y suction pipe too. Have a good listen around for hissing the manifol area when the car is idling.
Saw your car parked up on Greenway Rd this morning. Snow was interesting on Friday but isn't too bad around us really.
By the way a cracked dipstick pipe is common & that is part of the PCV system.
That wasn't me lol, if its on the left by the flats then it's my stunt double, it's a tdi I think, with a bit of bling, my mate keeps asking if it's me. I've told him I don't know times !!
I may take you up on those pipes, I'll let this crappy weather clear first, bit cold to be stood out the front lol
I did change the dipstick holder about 2 yrs ago, I suppose it could be cracked again
Oh twas a TDI then. I thought it looked a bit high up for a VRS. Black spiders fooled me!
It's worth you changing the small PCV that fits into the T pipe that the S pipe connects to. It's a cheap part from TPS & is prone to failure.
Thats the one. 2nd photo down large jubillee clip with S pipe going into it.
Jamie is a cool bloke really helpful. If you see him tell him the A4 rear flaps Paul bought that ETKA state as not for S-Line actually do fit the S-Line perfectly.
Pics 4,5 & 6 show the T piece PCV perfectly too.
nIce one, I'll tell him about the flaps.
Cheers Dave. Give me a shout if you need a hand with your car.
Have you got VCDS? If you have what's your requested v actual boost looking like?
All good as far I can tell, it's giving what I'm asking, so if there is a leak it's after the turbo ....I think lol
I may very well take you up on that. Nice one dude
MY ISSUE WAS WITH THE Z PIPE TINY SPLIT CAUSING OIL SPRAY AND PRESSURE LOSS SO SWAPPED THE PCV AT THE SAME TIME MY MPG AVERAGE IS ABOUT 21 lol shouting soz , i only do 4 mile each way for work so t expect crap mpg 40 plus on m62 etc
