Shark Fin radio antenna & Genuine FM aerial
Before anyone says "I told you so", the shark fun I have works quite well for FM reception in areas of reasonably good signal.
Unfortunately, I have discovered two 'black spots' in rural Herefordshire on my drive to work, so it's not a viable option for me.
It does work as above and has been fitted for about a month. No scratches or bangs. Looks in very good condition.
It has a RAKU II connector which plugged straight in to my pre-FL Octavia aerial cable. It is not a Skoda/VW genuine part.
Getting under the headlining to swap aerials is fidly but not too hard (easier if you have small hands).
I also have an original Skoda aerial that also works although the rubber on the whip has started to perish a little. This also has the RAKU II connector.
£10 each including postage.
Pictures to go up this weekend.
Both still available.
Shark fin was only on car for about 4 months mostly not plugged in as I've discovered another way of getting radio reception.
Do tell, dahling, do tell :))
Regards, Mike
All will be revealed soon enough (but its not really that clever).
  • 4 months later...
Both still available if anyone is interested.
Is the Shark fin Black in colour, any pictures when It was fitted to your car?
It is black, but no pictures of it futted I'm afraid.
I'll try to post some tomorrow of it unfitted and you'll have to imagine the rest.
I can post pictures of my estate with a similar shark fin fitted if that helps?
Here's the shark fin antenna and connector:
Excellent condition. Includes the nut needed to hold it in place.
post-59543-0-47642000-1371303747_thumb.jpg post-59543-0-32350400-1371303774_thumb.jpg
Excellent value at £10.00 including postage to mainland UK.
And here is the standard antenna:
post-59543-0-97832000-1371303822_thumb.jpg post-59543-0-64147900-1371303844_thumb.jpg
I'm reducing this one to £8.50 including postage.
Can I have shark fin one please...
mate is this shark fin branded or some random company made??
Shark fin provisionally sold.
Just in case, its an unbranded one. Not a genuine VAG part.
AFAIK VAG don't do a shark fin that does just radio reception.
Guest
