Fabia vrs led front fog into Octy vrs
Hi, Just fitted some 2011 fabia vrs led front fog lamps into my 2012 octy vrs, Fittment is direct slight wirring difference but sorted (fabia has a 3 pin connector on the fog lamp, 1x earth 1x lower voltage for side lights and 1x front fog lamp, so just used earth and fog connector). My question is can the cold start diagnosis be turned off via vagcom as i cant seem to find it and i am obviously now getting bulb errors because there is no load on leds and the car thinks its got a bulb out. Thanks for any help Phil.
  • Replies 85
  • Views 15.9k
  • sherlocks VRS
    sherlocks VRS
    Yes when i turn the front fogs on they work with no prob but i am obviously getting a bulb warning on the dash and also when you turn the ign on and the cars system does a bulb check i get a mommenter
  • LED fog on, normal DRLs at 'night' setting Halogen on left, LED on right:
  • I fitted mine yesterday along with a 50watts resistor but I am still getting a bulb out warning. Any ideas?
We need pictures!
I was looking for someone brave enough to try this last year!
http://www.briskoda....ut#entry2386776
When you turn on the front fog lights do they still work?
Did you have to use VCDS to activate the 'use fogs as DRL's' setting?
I'm sure the cold start diagnostics can be turned off but then you'd lose the feature for other bulbs. I think you can wire in a W5W bulb to increase the load and hide it behind the bumper...
Edited by silver1011
We need pictures!
Yes when i turn the front fogs on they work with no prob but i am obviously getting a bulb warning on the dash and also when you turn the ign on and the cars system does a bulb check i get a mommenterialy pulse from the front fogs. I did think of tricking the system as you have mentioned by using a bulb or even using a bulb warning cancellor. Ive been into vcds into 09 central electrics and long code helper but there is no facility to switch the cold start diagnosis off as far as i can see. The fogs do look better than the standard bulb type and seem to be brighter. Havnt yet taken any photos as i am still trying to sort these issues out but as said they fit straight in using the original fixing holes. Phil
Great mod Phil, I might do the same now.
Someone more knowledgable will be along soon to sort you out with the cold start diagnostics issue.
Don't forget some pictures when/if you get a chance. I'd love to see what they look like!
I was thinking of this for mine, some pics would be great!
I've done this to mine a while back but also have the bulb warning on. Anyone near Edinburgh willing to help me find a coding solution for this? Will post some pics tomorrow.
Interresting:)
ive done this too out here in Australia, also get the bulb out warning.
I cant find the cold diagnostics to turn off either!
WP_000016.jpg?psid=1
WP_000012.jpg?psid=1
Edited by zei20t
Just a little update, There is no way of switching off the cold start diagnosis for front fogs on a fl octy, so i spoke to a technical chap who deals with this sort of issue and ive been told just to use a bulb warning cancellor so i quickly made a temp loom up to try them and they work with no bulb errors so i am now in the process of making a couple of wirring looms with bulb warning cancellors fitted and then fitting the led fogs, They will still pulse 3 times when the ignition is initially switched on due to the nature of the cold start diagnosis on the car but i will have no bulb errors on the dash. When ive fitted them i will take some photos of the looms ive made and also with them fitted. Phil
Nice one Phil!
If you find the time a quick 'step-by-step how to' would be a huge bonus too :happy:
Just out of curiosity did your contact know if the colds start diagnostics could be disabled on a pre-facelift?
Nice one Phil!
I had a 57 plate vrs octy and fitted some hids and turned the cold start diag off on central electrics with no issues, will try and take some step by step photos at the weekend when ive got some time. Phil
:happy:
Very interested in this too guys :)
hope you dont need to use them for what they were designed for anytime soon, sorry but dont see the point when you already have LEDs right above them, maybe on a pre fl would look good, more modern.
no coding!!! damn. ok inline resister time.
thanks for the confirmation
hope you dont need to use them for what they were designed for anytime soon.
To be fair the fog lights on the vRS are pretty useless in fog anyway.Not to mention the fact that I can't actually remember the last time I used my front fogs.I have the cornering fog light function activated on my pre-FL just to get some use out of them!
Hi Sherlock, did you get a chance to do the dummies guide for this? :think: I would really like to get it finished but wouldn't know the parts to use.
thanks Silver, but I've already got them installed... did that a while back and bought the parts from skodaparts.com. Very reliable and even cheaper than ebay. It also tell you the part numbers for the plug and cables. The magical bit of info is the electronic trickery which I am no wizard in :) Sherlock's comment above was "a couple of wirring looms with bulb warning cancellors fitted and then fitting the led fogs"... I was looking for this in a dummies guide... buy parts x and do steps a, b, c
thats pretty cheap imo. They are less than Honda used to charge for Projector style fogs on the MB6 (before they stopped making them)
I like the idea of this!!!
They do look good and a noticeable brightness compared to halogen.
Hi
Could you tell me which of the 3 pins are ground and 12v please?
Also does the standard fog lamp connector physically plug in to the DRL unit.
Edited by atkinsong
no, youll need new pins and plugs to suit the LED lamp.
the square end of the plug is the ground/negative (I think)
the middle is the 30(40)% lit LED, and the round end is the 100% (which you should use for your fog light)
