Fabia vrs led front fog into Octy vrs
So do you get any bulb blown warnings. When I used a 50w 6ohm I got a bulb blown warning.
  • Replies 85
  • Views 16.3k
  • sherlocks VRS
    sherlocks VRS
    Yes when i turn the front fogs on they work with no prob but i am obviously getting a bulb warning on the dash and also when you turn the ign on and the cars system does a bulb check i get a mommenter
  • LED fog on, normal DRLs at 'night' setting Halogen on left, LED on right:
  • I fitted mine yesterday along with a 50watts resistor but I am still getting a bulb out warning. Any ideas?
No don't get any warning lights
  • 4 weeks later...
Guys, sorry for the maybe ignorant question - will the cornering function still work after the swap?
Yes it does.
Yes it does.
Hello my friend , tell me please When you used a 50w 6ohm do you have any faulse or warning lights in dash panel??
regards
vv
When using just a resistor I used to get a bulb blown warning. I ended up wiring in 5w side light bulb holders. This was the only way I could get the warning light not to illuminate.
Is the plug the same for p-fl and fl for foglights?
Im putting these fogs onto my pre-fl just wonderin if i'll need a new plug
Not sure but the receptacle on the back of the LED DRL's is different to the original plug on both the pre-FL and FL Octavia's so either way a little wiring work is required.
How are you going to mount them? Have you made an adaptor bracket of somesort?
Me? i have a facelift front.. just having time to fit it lol.
I need the DRLs too but can find them anywhere :(
Ah i see. Was gonna say they wont fit a pre-fl as the mounting points are different
  • 3 months later...
Dan, thinking of doing this myself. Do you have a link for the wire harness you used please?
Can't you just replace the normal bulb with leds?
Yeah you could, but there would be a bulb out warning!
Can you get canbus ones then?
Never seen any, might be able to use those resistors with cables ready to attach tho which you get with some hid kits
  • 2 months later...
May be the way to go then.. I might have to look into this a bit more, still surprised to find no one who has actually done this on a 2007 model VRS
 I have an LED unit for sale in the for sale section with a cracked front glass if you are still interested in having a look at this mod to see if you can get it sorted out.
I've been fitting mine today and they wouldn't fit without a bit of trimming around the hole
Take lots of pictures, there are plenty of people on here who would love a step-by-step guide!
Still available to anyone who wants it.
I'm ordering some wiring with 50w 6ohm resistors fitted so ill see what I can do when I know it works
Fitted and all working
But no pictures!?
Did anyone manage to get a guide with what to do with the wiring, and part number for new plug needed?
