MFSW fault, need help as dealer say they cant see anything :(
I've been having a problem with my 2009 FL Octy VRS DSG, sometimes the MFSW just stops working, no radio, maxidot or DSG padles. Then if you wait a min or two, it will come back again. Normally once the car is fully warmed up, it stops doing it.
Driving me crazy as it's been into Benfield Skoda twice, before warantee ran out and they said they cant find anything.
I even asked if they have read fault codes which they said they had and found nothing......funny as I have VCDS and I get the faults below
Any advice guys, either on the fault or how to get what I need from Benfield?
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 056 0111
Coding: 0001632
Shop #: WSC 73430 790 00999
VCID: 76E9C2980161CFA80B9
Subsystem 1 - Part No: 3T0 959 537 A Labels: 3C8-959-537.CLB
Component: E221__MFL-URO H07 0011
Coding: 00000131
Shop #: WSC 00000
1 Fault Found:
01426 - Controls in Steering Wheel (E221)
004 - No Signal/Communication - Intermittent
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1Z0 035 156 F HW: 1Z0 035 156 F
Component: BOLERO 008 0053
Revision: 0A001001 Serial number: SKZ1Z3I8165226
Coding: 050004000001
VCID: 356B05949CE784B0C23
1 Fault Found:
03138 - Input AUX IN
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 71
Mileage: 74401 km
Time Indication: 0
Date: 2101.14.08
Time: 14:08:37
did you show them the scan?
Could be the loom or a fault with the buttons
You can check in the MVB while the car is cold to see what functions work
The aux-in fault is due to leaving the Extension cable in the socket when nothing is connected
Hi,
Thanks for the point on the radio fault, I was wondering if it was something to do with that but from looking at the internet, I sounds a lot like the slip (clock) ring is faulty and causing an intermittent connection fault. Might also explain why it is effected by temprature?
My first thought on reading your post was the slip ring, does problem seem to manifest at a particular steering angle?
It was the "clock spring" apparently a common fault at around the 50K mark,, all fixed! Glad I mentioned it when the car was still under warrantee :)
