VRS TFSI INDUCTION KIT
Hello all,
I recently fitted a typhoon induction kit to my car.
Problem is that when its on full throttle at 4500rpm and over there is a loud whistling noise.
Has anyone else got an induction kit or could anyone shed some light into the problem?
i dont think its a problem.
My old Civic used to whistle at certain points of the rev range like that
Just sounds so crap. Every other induction kit ive had for other cars has mad a deep roaring noise.
Least i can feel an improvement in performance i guess.
I have a venom kit , it makes a nice roaring noise. Is the noise constant ?
so its not just a whistle at 4500rpm your questioning?
Its a loud whistling noise that it makes (only at 4500 and above) and only on full throttle...
i think my dbilas kit also makes this whistle noise on full chat
Same issue with my cone filter. Makes an odd noise when the turbo comes in- almost like a squealing, whining sound. Not sure if it's normal!
Sounds like just the air rushing in and at 4500 rpm something resonates .....!
thats probably exactly it.
Remember the engine isnt designed to have these kits fitted, they are designed to be as they are so changing the way the air enters the engine you will get issues like this.
As I said, when running a cone filter on my old civic it made an odd whistle at a certain revs because of resonation inside the intake
Yep, I think its normal mate. I've got a typhoon fitted to mine and it sounds like a harmonicca :wall: Tried alsorts to sort it. Even wrapped it in exhaust heat wrap to see if it was the pipe resonating but its not that and theres defo no leaks i can find. Its soooo annoying. thinking of changing the filter to a pipercross one to see if its that
This happens on most TFSi's with intakes but only on the K03 equipped cars. It is believed it has something to do with the design of the diverter valve housing causing the whistle.
Thanks for all your help!!!
  • 4 weeks later...
Hello again all...
Its really bugging me!!! How can i sort it?
Remove the induction kit?
Apart from fitting a K04 or going back to the OE engine cover there is nothing that can be done to fix the issue. It is internal harmonics caused by the K03 turbocharger. The only difference between the K03 and K04 design wise is that the dv housing is remotely located on the K04, whereas the K03 has it built in. It has been suggested that the noise is created when the air is being sucked in over the dv housing.
just remove it put your old cover back on and a decent ITG filter in, will probably be better in my opinion.
BSH tru seal is famous for it - swapped mine out for an Evoms and the noise went away.
