Hi all,
first post here on briskoda after purchasing a 2005 mk1 octy vrs. I have just had it serviced (110,000) and there seems to be alot of minor problems and I would like to fix them all myself however I am a complete novice.
'N/S/F back plate corroded and damaged':
I understand this is some sort of cover that stops stones etc getting into the brakes? cant seem to find a replacement on the web however.
'Steering gaitor clip adrift - O/S/F outer steering gaitor clip missing'
have had a google but nothing comes up :/ have no idea what it is
'N/S/R shocker bump stop deteriorated':
replace shocker bump stop I assume?
'OS/R bump stop and cover adrift':
Think I found the correct part here however am unsure if powerflex is a good brand http://www.ebay.co.uk/itm/Skoda-Octavia-1U-96-04-Powerflex-Rear-Bump-Stop-Kit-BS2006K-/370694935739?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item564f23d4bb&_uhb=1
'both front lower rear arm bushes separated from bonding':
found OEM part but have seen people on the forum saying superpro bushes are the way to go.
http://www.ebay.co.uk/itm/140707891331?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Any help on how to get the parts required would be extremely helpful also the level of complexity of replacing each part as I am a novice and have never touched a car.
Many thanks,
Ben
Steering gaiter is an easy one, rubber cover that goes over the track rod end, just needs a cable tie.
Sent from my Galaxy S3, not a Crapple!
hi Ben, i use these guys for a lot of my spares http://www.vwspares.co.uk/
ebay is a good source of spares, i may have a back plate actually, will have a look.
Steering gaitor, is probably the rack gaitor, there is one left and right with the tie rods attached.
Bump stops are easy to do, if you are used to taking apart suspension, its not a novice job to be honest if you have never worked on cars, though is easier than the fronts at least. You need to take off the top mount, and fit new bump stop/covers.
Superpro bushes are good, but again wishbone bushes are not generally a novice diy job (tho can be done), as usually need a press, and someone who is happy taking apart the front end suspension (undo from subframe 2 bolts and split balljoint off of hub), then press out/in new bushes.
thanks for the link Oet,
there are two options to choose from in relation to age:
1997-2004 and 2004-2009. Mine is an 05 plate mkI however I am under the impression 2005-2009 relates the the mkII so I should choose the 1997-2004 perhaps?
thanks,
Ben
Edited by Stormspire_1991
Mk1 is always listed to 2004.
The rear suspension is soo easy to do, just 4 bolts to undo from outside the car
Get yourself to south yorkshire pub meet on first week of month
no probs Ben,
yes it is Raf, but if you have never worked on a car, suspension is one not to learn on really.
yes 2005 onwards is mk2 generally
I had never worked on suspension before till it started off with replacing the rear springs followed by a rarb and finishing off by putting coil overs on, personally I think that the octy rear end is the perfect place to start to learn as there's nowt much to go wrong
Will do when I have a spare weekend. spend allot of my weekends with the army so busy quite alot of the time. thanks for the invite (:
Sounds like the best place to start then thanks Raf. Halfords have what seems like a nice little set of tools to get me started and half price atm (link below) unless anyone else knows any better.
http://www.halfords....tegoryId_255215
Is this enough or do I need specialized tools for work on the suspension?
Found this over at pistonheads, guess it rules out buying a haynes lol >_<
Rear bump stops are quite easy to do. The shocker sits next to the spring rather than in it so the springs don't need to be removed. There are about three bolts each side that need to be replaced in the process. Only the bolt at the top of the shocker is the difficult bit.
Sent from my Nexus 4 using Tapatalk 2
Make sure that you get the right bumps stops too. The vRS has shorter ones than the lesser models.
Talking of which, where do you guys get your rear bump stops from. Eurocar parts sold me something which they claimed where bump stops but weren't. Is it pretty much a dealer/TPS only item? Mine seem to fail after about 100k :-(
vw spares for me
Going to buy Bumpstops Rear (not 4x4)->VRS (105mm). Part No: 100512001
http://www.vwspares.co.uk/octaviasuspension_rear.php
Just going to contact vwspares first with my chassis number as confirmation of correct part chosen.
Ben
Just replaced both rear bump stops without too much hassle, 1h 30m for a novice so quite a quick and easy task.
Many thanks to those who helped! (:
Just had timing belt done however and its now a tooth out and misfiring so ringing garage up Monday morning and getting them to trailer it back to the garage to have it sorted :/ just hope it hasn't damaged the internals :'(
should be ok with 1 tooth out.
