Wheels sizes
I have recently purchased a Fabia vrs and was wondering can you fit 9j on the back 7.5j on the front? And What sort of offset would I be looking at?
In the absence of useful replies here, you might try searching this forum. I tried searching for 9J and found some threads that might provide useful information. You need to be aware that the wheels aren't meant to stick out further than the body parts, (MOT requirement I think), so you may need to modify the wheel arches to accomodate, depending on wheel diameter and tyre size.
Yes you can is the short answer ;)
offsets ur looking at min et20 all round
Thank! do you know roughly the max et I could go?
Depends what kind of fitment ur after..
Et40 front and probly around et30 rear... is the highest but depends what brakes etc uv got as to whether the wheels will fit..
Not too much of an issue if the et is high though because u can just space them out using... you guessed it... spacers lol ;)
Good luck m8 :)
