Coil Pack.
The vRS has been missing slightly on and off last couple of weeks.
Yesterday was really bad, then this morning it started on 3 cylinders and took a good few mins to clear and start on 4.
Took the coil packs off for inspection and found this.............
That'll be ya problem there.
There's a recall on them. You may be lucky and get th changed for free.
Check out the sticky
That's not right!
water ingress prob been jet washed at so point
or spark plug not done up right - get that checked before buying a replacement coil
btw if you need a coil I have 3 spares, pm me
Crusty
yes could be condensation from plug not being tight
Cheers guys. Been at it tonight and the plug wasnt tight. Seems to be better but will need a proper run to make sure.
