Drop links
Hi I've got a fabia mk 1 I've just put Jom coilovers on the anti roll bar is rubbing on the drive shaft so I need to fit shorter drop links today can anyone tell me any that fit? (Other cars that have shorter ones standard)
Mondeo drop links ...£10 a pair on ebay
Cheers lads just been and got a set will be fitting them shortly
Can these be fitted without lowering the car? As a precaution before I lower it?
Wouldn't think so...I wouldn't personally bother unless lowering with coilovers and some come with droplinks
Yes.
All they will do is pull thr ARB up slightly which will not cause any issues..
Remember though when u fit them u will have to remove them when u take the front struts off 2 lower the car.
The £10 ebay ones are a 1 timr fix because the bolts + thread on the ball joints are so cheap they seize on and u will most likely damage them + req new ones when refitting struts ;)
