Quick console bush question. Cupra bush
going to get my cupra console bushs fitted this week. have they to be lined up a certin way like the original ones? there is a white dot on each bush. i take it this lines up with something?
Put the dot to the inner edge m8 :)
cheers. will the wishbone only go in the one way then or do i keep it level???
Just push it in + bolt i up bud.. it will sit however uv lowered it.. if u get me lol..hard to describe :D
I fitted my bushes at a slight angle because my wishbones face upwards slightly at ride height.. if yours isnt massively lowered.. put the bushes in as if the arms were straight ;)
Push the wishbone into the new bush, put the balljoint into place and THEN tighten the front bolt for the front wishbone bush.
This will stop the front bush getting twisted and also make the balljoint alot easier to fit :)
Good luck!
cheers. car is at standard hight
